Intake Gasket replacement
Hey guys,
I received a "intake gasket starting to seep" inspection report from a recent stealership visit. I know I've seen it here before but can someone please let me know what an intake gasket replacement job should run me? I am not convinced yet of the diagnosis have to get in there just a whiff of coolant smell. Just in case you are wondering, the stealership quoted me $2100..:eek: Many thanks |
That's steep, if you are handy you can do it for a couple hundred $.
way too much
I take it that this is the valley pan gasket? Upper intake? Where do you see coolant at?
If it's the valley pan it shouldn't cost more than $850 or so at an indy mechanic. If the head gaskets are bad it could be around $1,200- 1,800 depending on where you go.
Thanks guys, I haven't seen any coolant yet just a smell of it. When (if) it stops raining on the east coast I will get out there and let the thing get hot and try to see if I can ID the source of smell or leak. It could be a hose clamp for all I know. What I am curious about is whether or not it is a given that these gaskets are going to fail at some point?
2004 SE7 55k pampered miles |
My 02 has 123,000 with original everything head gaskets, intake...never been apart. Now my 01 with 90,00 has had head gaskets, lower intake...whole shebang. Keep your fluids fresh and at proper levels I belive is the secret. TC, diffs, brake coolant. Watch them all. Oh and swith away from the dexcool to Peak lifetime.
harbor freight has a preasure tester with the correct adaptor for a Disco 2 for $59.00. I just picked one up this weekend when I was rplacing my head gaskets and timing chain.
| All times are GMT -5. The time now is 04:44 AM. |
