Intake plenum question
I'm going to put new plug wires on my D2 tomorrow but I can't find the torque spec for the plenum bolts for when I put it back together. If anyone knows what it is it would be very helpful. All I can find here at the shop I work at is labor time and parts prices but no torque specs. I'm sure I could get it close by how they felt coming out but I'd rather not do it that way.
If anyone in the Lincoln/Roseville area wants to hang out and watch send me a PM and I'll get you directions. |
Download the Rave CD and will tell you step by step what to do, the torquing sequence plus the torque values for every bolt.
2. Using a new gasket, position upper inlet
manifold. Fit bolts and, working in a diagonal sequence, tighten to 22 Nm (16 lbf.ft). |
First with a 99, don't remove the manifold.
If you want some help with this, send me your number and I'll walk you thru what to do. What brand of wires are you installing? |
I found the sticky for doing them without taking the plenum off, got them done in just under an hour. I used STI/Bremi wires they are the OEM supplier for most of the German cars ignition parts.
