Just bought a disco 2, doing a head gasket job, etc
He did mention the rear most head bolt on driver side head was a bit**. Of course that's where my coolant leak was to begin with. He said he broke 2 sockets trying to get it "rave" settings. Ill be nervous after I get it back, not gonna lie. Just want to try and enjoy this thing some! After this job and other fluid and misc repairs and maintenance plus cost of the rig, I'm out roughly $6k!! I prob could have shopped longer and found a nicer one!!
Not sure if your tech was aware but, Each valve cover is fastened with TWO different length bolts. The outter most bolts are a different length than the inners.
adamwest21 (10-29-2015)
Yea sorry, the heads are on and good and spec torqued. He was putting the valve covers on and said 3 bolts were stripped on those. On the repair bill, its 20 hrs flagged, 10 for the head gasket job, 6 for the ball joints(??) and 4 for trans, difs, tran case, oil pan gasket and some misc hoses. I work in parts and at 10% over cost, I have roughly $800 in parts. Machine shop charged $350 for custom sleeve press job, cleaning, resurfacing. About $150 in fluids, another $140 in OE LR parts and $150 in plugs, wires, and ball joints.
that counts for something
i would think you would better either helicoil the hole or find a couple studs that will fit, only because you will be continually tightening the valve cover bolts over time. it you get a longer bolt it will bottom out and not leave you room to tighten in the future. jmho
