just died
on
Bet you have a bad alternator, that is unable to charge your probably near bad battery, or if the engine turns over at it's regular speed and won't start the the crank sensor may be gone.
Go try to start it tomorrow, if it starts, it is the crank sensor.
If you have any question, since you ar local, send me your number after you try to start it and we can talk.
Like Mike says, sounds like crank position sensor. When it cools off spark returns. You can pour cold water on to cool it off also, it is shown on attached pix, the sensor is bolted to the engine under a little cover (just follow the wire down), driver side rear of engine. If you DIY the replacement, be sure to draw exactly which bolts come from where and where the spacer is. Many have put in a new sensor, still would not start, because spacer was wrong.
