Key.....
I wonder if you have time to answer another button question? I had never noticed this button below my steering wheel today and I cannot figure out what it is or find it in any diagrams. Do you know what this button is?
The previous owner was an eccentric boat captain.
No doubt not a LR switch. It looks a lot like the switch HELLA (and others) use in their lighting harness for driving and fog lamps.
Also check the rear of the truck, on top/sides and under the bumper for lights. Often people mount lights in the rear for additional backup/reverse.
If you really want to know what this switch does or did just trace the wires. At some point you will run into a relay and so on...….
Maybe the eccentric boat captain used that switch to power a bilge pump to remove the water from the leaking sunroofs.
HELLA lighting harness...
user 739349 (02-05-2019)
Had same issue. Carefully solder the key together (without filling in the edge 'teeth') and take to ACE hardware. ACE has these key blanks and can cut a new key for a few $'s...... I do not remember the actual key blank code....but it was a standard blank....
NOTE: ACE will only cut their own key blanks.......no questions, no paperwork needed...
I told my dad about your bilge pump comment and we had a good laugh. Dad's a commercial fisherman and I grew up working on boats. We are quite familiar with bilge pumps. LOL.
