-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Key stuck in, can I just leave it in? (https://landroverforums.com/forum/discovery-ii-18/key-stuck-can-i-just-leave-35500/)
Princess Nov 7, 2010 06:38 PM
The key won't come out every time. I did do a search and it seems it might be the switch letting it know it is in park. And it is intermittent.
Question is can I just leave the truck unlocked and leave the key in? Or will the security system lock me out?
Spike555 Nov 7, 2010 06:47 PM
No it will not lock you out.
Next time it happens try pushing the gear shift farther into park.
Hit it with the palm of your hand towards park and see if the key comes out.
Princess Nov 7, 2010 06:55 PM
Thanks, just getting it ready for winter duty. I was just leaving the door open when the key sticks in but that runs the battery down.
Spike555 Nov 7, 2010 09:07 PM
You can always take your wife's key and lock the door with the key in the ignition.
Fireman Nov 8, 2010 12:25 PM
Put your Transmission in Neutral. Shift your TC into neutral, then hard back into High. Then shift the transmission back to park. Try the key...
Princess Nov 13, 2010 12:42 PM
This does indeed release the key but after a few times driving the key again won't come out.
Fireman Nov 13, 2010 04:17 PM
Do you get an audible warning or warning lights? I think what is happening is the truck 'thinks' it is out of gear (i.e. in neutral). When in neutral, the truck will not allow you to remove the key. It is probably your transfer case interlock solenoid on the top of the transfer case. Read the following...
Transfer box interlock solenoid - Automatic gearbox vehicles
An interlock solenoid is fitted for North America and Japan. The solenoid is located on the top of the transfer box main casing on vehicles up to 03 model year or on the selector lever assembly on vehicles from 03 model year. The solenoid is connected to the transfer box relay which, in turn, is controlled by the IDM. The purpose of the solenoid is to prevent neutral being selected on the transfer box when the ignition key is removed, thereby locking the box in either high or low ratio.
novadisco2 Nov 13, 2010 08:42 PM
I saw a thread the other day on here where a guy disasembled his lock clyinder and repaired it for this problem. Had lots of pictures and was pretty detailed.
Spike555 Nov 14, 2010 10:41 AM
That is now a sticky in both tech sections. (DI & DII)
Princess Nov 14, 2010 11:39 AM
It does come out if I put the car in neutral and move the gear selector to neutral then hard back to high. So seems like not the lock cylinder but a switch not noticing PARK. Does this make sense? Anyone know how to get at the switch?
