Land Rover Mechanic/Shop In NYC Tri-State Area
Can anyone here recommend a good Rover Shop or Mechanic in NYC or Tri-State Area. Initially I had heard about Rover Repair NYC but after reading some Yelp reviews I think I'll pass on using these guys. Any suggestions would be greatly appreciated and thanks in advance!!
Thanks Frankie |
Are you in NYC or outside the city?
Originally Posted by matt3502
(Post 597920)
I'm in Staten Island, but right @ the VZ so about 10 minutes to Downtown via the Tunnel. Thanks Frankie |
There is a member here from Staten island too, Mollusc, he might know someone around there. There is one here in Nj, RoverMasterTech you could probably check them out.
I haven't looked for anyone around here but my suspicion would be that there's nobody on the island. I've done all my own work.
If I ever truly needed to take it to a mechanic I'd probably head to NJ. |
Originally Posted by DrDash
(Post 597912)
Thanks Frankie |
Check this out as well.
Euro Motors - Look for Vic 1 south ave, Garwood NJ 07027 908-232-1783 The owner have Land Rovers I used to go to them when I was rich and now Im poor because I have 2 of them, lol. Now, I decided to fix them myself. Problems with fixing and maintenance often can be solved using this forum. Good luck gerry |
What do you need done?
Carlos at British Auto Works. Probably the best Rover shop in the tri-state area, and definitely within the 5 boros. Couldn't recommend them more.
Land Rover, Range Rover Repair Service and Maintenance | Westchester, Queens, NYC, Bronx, NY https://goo.gl/maps/qxFpV4JYSGp |
I have not used these guys ( I live in CT) but I seem to recall seeing their names here:
Outback Garage Bay Shore, 11706 Long Island, NY 1(631)560-9071 Outback Garage ? Independent Land Rover Specialists |
