Leaks, damned leaks, and Disco2 Leaks
Old 03-04-2023, 04:29 PM
keninnc's Avatar
I have the same leak.
My hope is valley gasket has failed between the cylinder head and the lower intake manifold. There is an opening for coolant in the rear of the cylinder head that is blocked off with the lower intake manifold.
But if that is where the leak is the debate is to do the head gaskets or not since so much of the engine has been removed to replace the valley gasket.
Old 03-04-2023, 05:16 PM
Hendo6119's Avatar
Originally Posted by Hendo6119
Ok I have replaced:
1. T-stat
2. Water pump
3. Radiator (because I put a hole in it while replacing #2)
I am STILL leaking coolant on the back side of the engine bay. What am I missing? Heater core? Heater core hoses? Heater core hose connections?
I've noticed temps rise and heavier leaking when I run the AC. Not sure if that's related or not.
Old 03-04-2023, 05:49 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
Run your coolant tank cap one full turn loose from full tight, it won't build pressure and will leak less. Temps rise because AC increases heat in the system,
Old 04-20-2023, 05:40 PM
mackendw's Avatar
just drive in your speedo and run with full heat on...
Sabbe
10-14-2021 08:11 PM
jd06
09-02-2021 05:34 PM
Cnature2
08-02-2017 06:56 AM
Discovery steve
01-22-2014 01:43 PM
roxiemoxie
11-01-2011 05:36 PM
Quick Reply: Leaks, damned leaks, and Disco2 Leaks
