Leaks and Seals and drive shafts and...
Hey guys, took this to the local repair shop and this is what the guy said.
He re greased the drive shafts, check the fittings and everything looks good. The front shaft was recently replaced.
There is a leak in the TC and the transmission, although fluid is full so doesn't think its major right now.
As for the rear shaft, there is fluid leaking from the pinion seal in the rear differential, he says it has significant differential play and is causing the clunking sound when you put it in reverse. Should be repaired. Is this an easy job? Something that i could do myself, I called around to a couple of local shops and no one will work on a Landrover...awesome...anyway going to search for some threads on this so any help would be appreciated.
Thanks
Joe
Here is my thread on the transfer case. Have you downloaded the RAVE manual? I find the Disco fairly easy to work on if you get the right tools. I did my own headgaskets last summer.
https://landroverforums.com/forum/sh...=transfer+case
Nice write up, the pics help bring it all together...I will try to get this done in the next couple of weeks. I down loaded the RAVE but can't seem to get it to work, will download it again and see if it works probably a user error. Thanks appreciate the response on this.
