Leaky roof near A pillar
Little bit of everything for the end of the year - first three amigos, then four amigos, then windshield washer pump gave in, then my seat warmer stopped working and now leaky roof! And I just installed brand new headliner! Leaks right around the top of the A-pillar - mind you, I don't have the outside pillar trim installed and no corner piece on the gutter but not really sure if that would even matter. Headliner is dripping wet right around that corner - nowhere else.
Did you guys have anything similar happen? Really hate it now since I'm gonna have to take the headliner out to see what the problem is......... https://cimg4.ibsrv.net/gimg/landrov...3ee8177f03.jpg |
Did you recently have a new windshield installed? Check that top corner to see if it is sealed properly. The missing trim shouldn't make it leak.
I had that happen after a new windshield install, inspected, saw a gap, filled gap with clear silicon and no more leak. |
See my pics in the recent windshield thread. Having the same issue and suspect the body joint.
Windshield is still original. I do suspect a body joint as well as there is no other explanation to this. I'm gonna have to pull it into the garage and let it dry and see from the inside. Headliner unfortunately has to come out.
