Left rear wheel sensor fault
The sensors are robust but the ABS reluctor ring is probably gummed up with oil, grease and crud or it could be a plug/socket fault on the sensor. You can try blasting the reluctor ring with an air line through the sensor hole and turn the hub/wheel around whilst doing this. Obviously it will need to be on axle stands.
brooksa (07-31-2016)
kbarker27
10-13-2023 04:03 PM
hossiena
07-18-2013 10:48 PM
06Range
05-08-2013 09:01 PM
workinghard1713
04-16-2012 11:25 AM
