Lets Talk About Knock Sensors
Hi All
I have a 1999 D2 with a little knock problem. I just ordered a I930 scanner and was wondering if the live data will show knock sensor readings. When I monitor engine timing advance on my scangauge and it starts to knock I see no change in timing. It doesn't retard. I get no CEL or codes. I run top tier 93 octane fuel. I'm really hoping to be able to monitor knock sensors with my new I930. Have any of you had a faulty knock sensor that didn't throw a CEL code?
Hi All
Well I did look at the wires and they are attached at the sensors. They run towards the front and I couldn't really see where they end up. I should definitely see the timing back off when knock is occurring right.? Well my scanner arrived yesterday according to tracking. I'll check the mail box when I get home from work. Whether its a wire or a sensor I believe something is wrong.
As far as I recall, timing is dictated by a combination of inputs from the knock sensors, the MAF, and the crank sensor. Maybe the cam sensor, too.
The ECM calculates ignition timing using input from the following:
l CKP sensor.
l Knock sensors (KS).
l MAF sensor.
l TP sensor (idle only).
l ECT sensor.
also
In the event of a CMP sensor signal failure any of the following symptoms may be observed:
l Ignition timing reverts to default values from ECM memory.
l CKP sensor.
l MAF sensor.
l ECT sensor.
also
TRIARII
01-20-2014 07:55 AM
expeditionnw
10-18-2013 10:54 AM
98roverguy
08-02-2010 05:28 AM
CandiMan
11-07-2008 10:57 AM
