lift
Old 12-07-2006, 09:46 PM
Doak's Avatar
Default lift
im thinking about buying a 2" coil spacer lift ($99 from rovers north) will that work with my air ride autolevel suspension?
Old 12-08-2006, 02:13 PM
Default RE: lift
I am not familiar with spacers from Rovers North, but I do have a set of spacers from
http://www.rovertym.com/ that I have been running for the last for years and they have worked very well and are adjustable for aditional lift.
Mike
Old 12-08-2006, 03:45 PM
phia@binoco.com's Avatar
3rd Gear
Default RE: lift
Spacers are the way to go. Cheap and easy. I had them done on my Jeep Wrangler, and it's the perfect amount of lift. Had them for over a year, and there hasn't been any issues. Go for it.
Old 12-08-2006, 10:28 PM
Default RE: lift
Spacers are for the rear air suspension not for a lift to compinsate for a tired suspension.
When a Disco's springs start to sag the only cure is new springs and shocks xcept where the SLS suspension is concerned.
Mike
Old 12-21-2006, 10:18 AM
Doak's Avatar
Default RE: lift
yeah my truck sags bad so i definitely want to replace all coils and shocks. mike which ome shocks do i want to use? i have been looking and keep finding different types. also what about bilstein i know they make some good stuff.
Old 12-23-2006, 10:47 AM
werldcup's Avatar
Default RE: lift
The Rovertym spacers state that the Disco II spacers are only available for the front and in 1". Will the Disco I spacers work? Also, the Rovers North spacers are of a completely different style (and consequently compatible with either Disco I or II). Anybody have an opinion on their functionality vs. Rovertym?
Old 12-23-2006, 11:06 AM
Default RE: lift
ORIGINAL: Doak
OME only makes two levels of shocks, standard and HD. Only use the Hd version for your truck, the standards are for soccer Moms that want it very soft, don't work well at all off the road.
Hope this helps.
Mike
Old 12-25-2006, 11:58 AM
Doak's Avatar
Default RE: lift
so no on the bilstein. and what about the ome dual reservoir? overkill? thanks
Old 12-25-2006, 12:37 PM
Doak's Avatar
Old 12-25-2006, 04:52 PM
Default RE: lift
I can get you the same coils for about $20 piece less.
Send me your tele number and I'll call you.
Mike
Quick Reply: lift
