Lift Kit: Can I remove passenger front shock tower WITHOUT removing expansion tank?
Hey there....
Is there any way to remove the passenger side shock tower (2004 DII) without having to remove the expansion tank, and re-bleed the cooling system? I am installing a new OME kit, and that tank is being a pain. Any suggestions greatly appreciated, already WAY over time allocated to this project (that's part of the love, right?) thanks, CJ |
Just pop it loose to get at those two bolts. Once loose you'll have room. You don't have to drain it or remove any lines.
this true
just dont snap the bottom nipple off the expansion tank when you remove it.....
Originally Posted by joyntanovich
(Post 501497)
Hey there....
Is there any way to remove the passenger side shock tower (2004 DII) without having to remove the expansion tank, and re-bleed the cooling system? I am installing a new OME kit, and that tank is being a pain. Any suggestions greatly appreciated, already WAY over time allocated to this project (that's part of the love, right?) thanks, CJ Refer to the picture below. Gently lift up the front of the tank and slide it forward. http://cdn1.bigcommerce.com/server12...0.1280.JPG?c=2 |
Got it. thanks so much!
