Locking differentials
The more I read the more lost I am. I have an 03 Disco and one of my future goals is to add true four wheel drive to it with locking differentials. If I go with an ARB kit would that include all I need, minus the AC, do I have to replace both diffs and the transfer case, just the transfer case, just the front and rear diffs....... I have tried to educate myself on this but I just get more confused. The answers I get stop just short of the info I need
The transfer case does most of the locking. There are parts inside the transfer case called differentials, they are of course different than the front and rear axle "pumpkins".
Some years of D2 had the fitting on the transfer case, but did not have the shift lever, and there are kits for those. However, I think your year needs extra parts. A pile of parts.
see Expeditions West: Land Rover Discovery II CDL
and
2003CDLInstall - LAND ROVER CLUB V.I.
and
on
I agree with Jafir. I true locked up truck, 25% power to each of the 4 tires will require converting/modifing your t/case to a CDL case then adding a rear and front locker to each diff.
If you want to explore your options, send me your number and I'll be glad to walk you thru all the lockers and what sort of money you are looking at.
Convert your center diff to a locking one then drive it where you'll normally be off-roading to see if you really need locking axle diffs. Even without traction control (i.e. D1's, Defenders, etc.) and a CDL Rovers are very capable off-road.
I think for the majority of the average owners a winch before axle lockers will be money better spent.
A winch may not have the coolness factor of axle lockers, but it will get you out of more bad situations than lockers will.
pilot063
08-22-2012 07:20 AM
