LOOUUD.
LOOUUD.
Hello,
I was wondering about my Disco II's sound. I notice when i start up the sucker has an almost diesel growl and like a clapp-clacking coming from the engine. It really just sounds like an older muscle car kind of sound. I notice is as soon as I start up and then it subsides, but once I accelerate it will increase in tempo.
I previously had a jeep Cherokee, so I am not sure if this is common. I never noticed it with other Disco's. When I had the truck looked at for another issue at the Land Rover dealership, I mentioned it to the mechanic and he assured me that unlike american cars, Land Rover's "don't hide their power sound." So I am wondering if it is normal or not. Any help would be great. Thanks.
2003 Discovery II SE7, 86k miles.
RE: LOOUUD.
Cracked exaust manifold, bad gasket or loose connection from the maifold to the downpipe. Take it to Midas and they will tell you what is wrong. Then you can get the parts to replace and do it in your driveway.
You can also fire it up cold and feel around for a puff of air (exhaust) around where the noise is the loudest. Look for cracks and gaps
Not normal. Your mechanic is nuts. When the exhaust is all working right, they are relatively quiet.
RE: LOOUUD.
Ok, when the oil pump goes bad the only fix is a new engine. The problem is this, when the block was forged the dowel pins that the oil pump seats against are mis alighned thus causing the the oil pump to wear prematurely and eventually fail. You can replace the oil pump beforeit grenades and save the engine, but you will need to replace the oil pump again when it starts to get weak, and so on and so on.
So, lets assume that the oil pump was replaced at 45,000 miles because it went bad, well the half life of a new oil pump would be about the same as the old one.
