Loud click when parked - ABS area - draining battery - TSB?
Old 01-18-2016, 03:42 PM
ejensenok's Avatar
Default Update
Removing the two connectors from the SLABS causes the SLS light to illuminate on the dash (yellow), but it does solve the battery drain problem. We have had enough time now to confirm the there is not anymore battery drain and the truck has started after sitting for 3 days. It was failing to start after sitting for as little as overnight and it would never start after sitting for a full 24 hours. So, if you can live with the SLS illuminated, this is a viable solution.
lrjon
12-18-2013 02:52 PM
discodaft
10-20-2012 11:28 AM
nahtanoj
11-04-2011 09:26 PM
toad2
07-31-2010 07:17 PM
hilltoppersx
07-28-2009 04:36 PM
Quick Reply: Loud click when parked - ABS area - draining battery - TSB?
