LT 230 Transfer Box leaking oil
I've noticed I have an oil leak where the transfer box joins the autobox. Looking at the oil it appears to be the heavier type as per the transfer box. Has anyone experienced this and how hard is it to remove and reseal the transfer box to the autobox.
I also need to replace the tranfer box output seals both ends so it might be worth doing it all at the same time. If anyone has fixed these leaks recently I'd be pleased to hear of their experiences. |
When mine got hot it started leaking also. I put miracle in a bottle aka blue devil. No more leaks. IMO it's worth a shot. White Shepard is also a recommended additive.
X2
I noticed a leak about 2 years ago. I did the fluid change and half a bottle of that White Shepard, expecting to be disappointed. Hasn't dripped a drop or missed a shift into low or lock since. |
Thanks for your inputs guys. But I'm afraid I've never been a great believer in these sorts of 'miracle' cures and the trouble is I would never be comfortable relying on them as I would be constantly concerned over what other damage they are doing.
It's a similar scenario to the Pajero injector pump front seal (mechanical injector pump), someone had the bright idea some years ago to put 500mls of brake fluid in half a tank of diesel and said it cured the seal from leaking. Yep, it sure does, by swelling all of the seals and gaskets in the injector pump equally. Unfortunately after a while there were a plethora of failed and ruined Pajero injector pumps which were irreparable. I think of this a similar analogy which to me is of concern. IMO I'd rather fix the leak mechanically with a new gasket or some RTV. |
Where do you guys get white shepard?? I've looked at autozone, napa, advanced, and o-rileys and none of them have it. My transfercase leaks too... I'm tired of checking and adding fluid once a month.
Autozone has a stop leak called "blue devil", It's the same thing. I just bought a bottle yesterday for $23 and put in the T-Case. Mine still leaks but it says it can take up to 2 days to work. Fingers crossed. If it doesn't work I still fell $23 is worth a shot before a pull the whole T-Case to reseal it.
BlueDevil/Oil stop leak (49499) | Engine Additive and Cleaner | AutoZone.com http://contentinfo.autozone.com/znet...49499/image/2/ |
Originally Posted by oilspotLR
(Post 477521)
I had a similar experience trying to track down another suspected "snake oil": Lubegard 60902. Lo and behold, it actually fixed my transmission shutter. Now Amazon is my go-to. |
I found the blue devil oil additive at pep boys. they didn't have white shepard
Thanks for the information... Good luck on having the leak stopped (slowed)!
Mine was leaking also. Brings up a low oil press xfer case code. Was a few loose bolts on cover. Tightned em up added 2 qts and was fine...4ft 3/8 hose hose clamped to diff lube bottle. Squeeze like hell. Hose pops of bottle a few times and makes nasty mess. Just a thought. If your SURE its the seal disregard this...
