MAF sensor FUBAR.
MAF sensor FUBAR.
Looking for some help. Been working on my 2003 Disco II and currently have the following codes:
P0101
P0102
P1884
Truck is running, but idles rough and doesn't respond as snappily as it used to.
After researching this forum (and a few others) the first two point to something with the MAF sensor. I pulled the "barrel" where the MAF sensor is housed and it looked clean in the tube and the sensor didn't look dirty either. I couldn't pull the sensor out due to the Torx security screws holding it in, but I did spray it with some electrical contact cleaner. Let it dry overnight, put it back in engine running exactly the same. SES light still on.
Is it most likely the MAF sensor or could it be something in the intake (leak?) before the sensor (i.e. sensor is fine)?
I'm assuming the P1884 is an unrelated code? Or is it...
Appreciate any help--love this forum as it's helped me with several fixes on my Disco.
P0101
P0102
P1884
Hope you didn't ruin your maf with that. This is the only stuff I use on the maf and it works great, but like buzz said make sure it's cold. Like after it has sat all night and give it plenty of time to dry. I usually wait around an hr just to be sure before restarting.
BTW - the reason for cold is that turning the key to position 2 applies power to the sensors, and that sensor has a small spot inside that is heated up way above ambient. The difference in readings over the hot part of the sensor and the un-heated part allow it to calculate the mass of air whishing by. If you hit the hot part with cold spray, thermal shock can make it crack. So don't crank truck to move out of garage, or turn key to listen to radio, etc. Don't use contact cleaner, brake parts spray, etc. Buy something made for it.
I let the truck cool, pulled the tube out and it sat inside before I sprayed it. I couldn't actually remove the sensor from the housing so Im not sure if the cleaner even penetrated the sensor enough to clean it. The CRC cleaner is cheap and I can try to pick up a Torx security set to remove it. Anyone know what size Torx that is holding the sensor?
Appreciate the help.
If you look closely, the bolts aren't exactly torx. They only have 5 lobes. Which I didn't notice until after I tried some security torx bits.
