magnecor wire install
Old 10-09-2007, 01:11 PM
mcneal's Avatar
Default magnecor wire install
Well my hat is off to anyone who changed their own spark plug *wires. I spent three maybe four hours yesterday attempting to change mine. Ive got more knuckles skinned that not, not to mention swollen wrists. Damn those a/c lines. Anyways, is there an easy way to get the 3rd plug *wirein, other than patience. Its the one on the bottom left middle when laying on top. I got all the rest. I tried the cold beer trick, tonight i might have to try hard liquor, my hands are pretty raw. Thanks in advance.
Old 10-09-2007, 07:59 PM
jkid's Avatar
Default RE: magnecor wire install
Hopefully my wires will be here soon. I'll let you know. I'm thinking a set of long reach 90 deg. needle nose pliers might be helpful at some point. Usually patience and a little creativity are the best things you can have. As soon as you get frustrated and start throwing stuff, that's when you know it's time for a break. You could always grab the nearest kid around with small hands and arms, they usually like to get dirty.
Old 10-09-2007, 10:34 PM
N.Franklin's Avatar
Passenger side doesnt look that bad, Ive had worse. What kind of deal did you score for the wires?
Old 10-10-2007, 06:23 AM
jwfuller's Avatar
There's a nifty tool at sears that may be of some help. Ask for a spark plug wire wrench. It is a scissor like tool with rubber grips on the end.
Old 10-10-2007, 09:12 AM
mcneal's Avatar
Thanks for the ideas ill be making a trip to sears after work. Patience is definatly your best friend. I dont have kids so thats out. However, my girlfriend is pretty small, might take some coercion to get her help though.
I got my wires from www.apexperformance.netfor $70 before the price went up. I think they might still be under $100.
Old 10-12-2007, 06:49 PM
jkid's Avatar
I just replaced mine in 1.5 hr. That was with really taking my time and helping a buddy replace his brakes at the same time. I found that I had totake offall of the old wiresfrom the coil first, ( rather than replacing one wire at a time like you should do) so that I had plenty of room to install the new bottom wires. I don't think that I could have done it one wire at a time. It also helped a lot to unclip the wiring harness running along the firewalland move it out of the way.
Old 08-24-2008, 11:01 PM
NiteTrain's Avatar
www.apexperformance.net has 8mm for $83 and 8.5mm for $106...im leaning towards the 8.5mm. Has anybody ran these?
Old 08-25-2008, 06:49 PM
NiteTrain's Avatar
anybody running 8mm?
Old 08-25-2008, 07:02 PM
Run the 8mm, the 8.5's wont fit in the factory wire holders.
Old 08-25-2008, 07:18 PM
NiteTrain's Avatar
ORIGINAL: Spike555
that was one of my concerns...but if the 8.5mm add more MPG it might be worth getting new wire holders.
Quick Reply: magnecor wire install
