Manual transmission flush questions
Old 06-19-2018, 11:50 AM
DavC's Avatar
Originally Posted by TRIARII
2 ways to flush the transmission as far as I know. Power flush using special machine or manually where you drain and refill until fluid comes out clean. 😆
The tranny went without fluid long enough to make it smoke a bit and cause the rpms to skyrocket. Probably 2 hours of driving before I was able to get to a place that had fluid.
As for how I refill the sump. Usually start filling while the truck is cold. Once full I start the truck and warm it up, shifting through each gear several times. Then while idling I add additional fluid to the sump until fluid flows out of fill hole.
When you use "manual transmission" what comes to mind first is an actual manual transmission, not the method used to service said transmission
The following 3 users liked this post by DavC:
mollusc (06-19-2018), Sixpack577 (06-19-2018), ZGPhoto (06-28-2018)
Old 06-20-2018, 08:34 AM
abran's Avatar
Man, you guys are so hung up on terminology. Whether it’s an inch or a mile, same thing, it’s a unit of measurement!
Old 06-20-2018, 10:53 AM
robertf's Avatar
I had the same thing happen to mine. If I hadn't read the follow up posts I would have told him to refill it with redline MTF and rock on. The synchros are much happier with it than ATF
Old 06-20-2018, 05:48 PM
DavC's Avatar
Smile
No substitute for being precise.
Old 06-20-2018, 08:51 PM
Alex_M's Avatar
Even 10 minutes, you burnt the hell out of your clutches. That's why the fluid smells burnt.
I'd say dump some stop slip in it and drive it till it dies.
And we all understand what he means by intercooler in this context. There are plenty of substitutes for being precise, such as speed just to name one.
Old 06-26-2018, 08:09 PM
TRIARII's Avatar
Sooo in a worst case scenario can the transmission be replaced without pulling the engine? Any ideas on how much a transmission rebuild should cost? Baring in mind I have a spare transmission with around 170k from my grey D2.
Old 06-26-2018, 08:14 PM
Sixpack577's Avatar
Transmission unbolts from engine and comes out from underneathe.
Old 06-27-2018, 09:34 PM
TRIARII's Avatar
and how exactly does one access upper bell housing bolts with engine still mounted in position on frame?
Old 06-27-2018, 10:01 PM
Alex_M's Avatar
Same way you would remove them if you were removing the engine without the transmission. With much difficulty.
Athana
06-08-2019 10:23 AM
luckyd77
07-02-2017 09:06 PM
Externet
09-22-2014 11:38 AM
edgarf23
10-02-2013 07:39 AM
danperrett
03-15-2009 09:38 AM
Quick Reply: Manual transmission flush questions
