Mass Air Flow
RE: Mass Air Flow
You may remember me from a month or so back. I was the idiot mom who had the check engine light on for a long time, with the mechanic that was also an idiot. After getting it back from 2300 dollars worth of work, it still did the same thing, sluggish, engine light blinking...the first mechanic did all of the stuff you guys said, (plugs, wires, etc.), new fuel pump. He apparently cleaned the MAF, and one of the posters here told me that you never clean the MAF and that the idiot probably ruined it. Needless to say, I found another mechanic who says it is the MAF sensor? Check engine is on and blinking...Does that sound right?
RE: Mass Air Flow
ORIGINAL: akc
Just an update: Mass airflow replaced, running good, but my local mechanic is seein a code of: 6th cylinder? What is the firing sequence? Unfortunatley, the check engine light is still on, but he is getting a 6th cylinder code. Thanks so much!
The firing order starts with the front driver side cylinder. It goes 1-3-5-7 front to back drivers side, 2-4-6-8 front to back passenger side of engine.
Cheers,
Pete
