Minor PS leak
Minor PS leak
I recently noticed that I have a minor power steering leak. I degreased the area and can't really find the leak. The PS fluid in the reservoir tank went down about a 1/4 inch this last month. I was thinking about using a stop leak additive. I am not sure weather to try Lucas or White Shepherd. I will also like to know how much to use, I have read that too much can cause even more problems. Thanks for any help that you can give me.
on
Buick
I had a leak at my pump and used the White Shephers P/S stop leak as per the directions and it works like a charm as long as you drive and or idle the engine for 2 hours have installing the additive on "NEW" p/s fluid.
Lucas, if you read the label, which most don't is a stop leak for internal leaks, not external .
Order some Whitesheperd, you will like the results.
