Misfire
Misfire
I have a 2000 DII with 91,500 miles throwing error code P0307. Cylinder 7 misfire. I changed the plugs and wires using the suggested Bosch Platinum +4 and Magnecor 8MM. Still getting the misfire code. Could the cause be the coil? Would just 1 of the 4 sections fail or would they all fail? Is there any way to check the coil by it’s self to determine if it’s working? I did remove the plug wire and attached one of the old plugs to it, ground the plug and did see it spark as it should. Any suggestions?
BIG greg
BIG greg
RE: Misfire
I've had good luck with my Magnecors and Platinum +4. Biggest problem I had is I shut one of the plugs in the drawer of my tool box while installing them and spent an extra hour looking for the plug.
I have heard of cracked plugs causing problems before. Also make sure the plug wire is seated all the way on the plug. I know #7 & #8 on my D1 were a pain to get the wire on all the way.
