mounting factory bush bar
You do have to remove the front bumper and cut slots in it for the bar mounts to go through. Remove the recovery loop on the left side. There are also two tabs (one per side) that fit between the bumper and the fenders, just in front of the wheel arch, that bolt to the bottom of the wraparound pieces.
This is all assuming you have a D2, and not a D1.
Edit: Judging from the post below, there were brackets that bolt to the frame
Last edited by lordmorpheus; 07-23-2011 at 05:58 PM. Reason: forgot there WERE brackets... ;)
You'll have one rectangular plug on the right side, as you're standing in front of and facing, your front bumper. That square plug will pull out. The left side of your bumper, you will need to replicate this rectangular hole. You'll also want to make sure the seller includes the two mounting brackets in this pic.
Make yourself a template of the right side with a piece of paper. Line up the bottom edge of the paper with the ridge on the bumper.
Grab the right side of your template and flip it over to the left side, like you're turning a page, so you're now looking at the back of your template, but have it lined up the same, just on the left side of the bumper. Trace your hole, and now you know where to trim.
Easy as pie! You can very likely accomplish this without removing the bumper cover. BikingTeacher has done this exact project and might chime in with additional tips if he sees this thread.....
Best of luck! Take lots of pics!
chamilka
02-24-2012 08:54 PM
ggothlin
02-10-2009 06:00 PM
