My 180 Thermostat Experience...
In another thread I mentioned replacing the electric AC condenser fan which was seized. Today I had the coolant system flushed, replaced with Peak Long-life mixed to 50/50, Water Wetter and the 180 thermostat. Here are my quick stats afterwards...
Sunny and 75 Outside 60mph 188 with AC 40mph 190.5 with no AC 60mph 186.8 with no AC Sitting still 5 min 201.2 no AC Sitting still 5 min 194 AC I am assuming the temp dropped when I was sitting still because the electric fan kicked in when the AC was switched on? All in all, I'm pretty happy with the results. Much better than I was getting prior to the flush and 180 thermostat installation. I suppose there's no way to really tell if the Water Wetter made much of a difference seeing as it was added post-flush. Guess that's a win for the "snake oil" but I'm feeling much better about my temp management on her. |
Did you get the motorad or genuine?
I went with the genuine from Rovers North.
This is the same temp range which I saw after I switched to the geniune LR 180-deg thermostat.
Trucks will be different, because of the internal condition of the radiator, so variations will be there. But it beat the pants out of 221F.
Originally Posted by shltn
(Post 422729)
(Post 422707)
Sunny and 75 Outside 60mph 188 with AC 40mph 190.5 with no AC 60mph 186.8 with no AC Sitting still 5 min 201.2 no AC Sitting still 5 min 194 AC I am assuming the temp dropped when I was sitting still because the electric fan kicked in when the AC was switched on? All in all, I'm pretty happy with the results. Much better than I was getting prior to the flush and 180 thermostat installation. I suppose there's no way to really tell if the Water Wetter made much of a difference seeing as it was added post-flush. Guess that's a win for the "snake oil" but I'm feeling much better about my temp management on her. My Stats. '01 DII w/ 183,000 miles. As far as I know its the stock water pump and radiator. Running on the Green Juice cocktail. No water wetter. Haha. I had a Motorad recently fail on me. The internal rubber gasket became dislodged and f'd the stats operation. Further, I never saw temps in the 186-188 range. The Genuine 180 is the way to go. |
(Post 422766)
Next up: my front drive shaft. I climbed under and I do have the original driveshaft. I tried to check for play / slop and didn't notice any but heck if I know if that's even any indicator. I can't get it rebuilt locally and don't really trust myself to do it - so looks like a new one will only be a bit more than shipping mine off to be rebuilt. |
For the front shaft. I recommend Great Basin Rovers or Tom Woods.
Originally Posted by ZGPhoto
(Post 422773)
Thank you for the order! I am glad it has worked out for you, it works very well.
| All times are GMT -5. The time now is 03:41 AM. |
