my new to me white 1999 D2
Old 03-11-2016, 07:49 PM
BS50MGSXR's Avatar
Got this in after work. Pulled all the old threads out and drove this in with the ryobi 18v 1/2 impact carefully and kept cleaning the hole and the self tapping drain plug. Finally got it in and then added the crush washer and torqued it down to 18 ft pounds. The little screw is torqued to like 7 ft pounds. I'll probably add some blue lock tight to everything tomorrow. Iv got a quart of oil sitting in the pan now. Will check if the plugs leaked any oil in the morning.
  #42
Old 03-15-2016, 08:00 PM
BS50MGSXR's Avatar
Ok, well at walmart and can't unlock the car. I was able to stick something into the door and pop the lock, but with the key in the ignition it won't start and the alarm just goes off for a bit. Can I pull the battery cables to reset the system? Can I drill out the driver side door to turn the lock?
  #43
Old 03-15-2016, 10:22 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Can you roll the window down? Do you have a remote? Normally if you operate the door lock from the outside to lock unlock it will reset the alarm. It saw the door open without a remote or key so it triggered the alarm/immobilizer. Either a lock/unlock via remote or door lock will reset it.
moorebl
11-10-2013 09:00 AM
essco22
02-21-2011 12:30 PM
psk8888
08-28-2010 03:02 PM
95raingerowver
02-19-2008 03:13 AM
wileyabbas
07-27-2007 03:48 PM
Quick Reply: my new to me white 1999 D2
