At my wits end
Double check all the spark plug boots are properly seated (coil and spark plug ends). Especially, cylinder number eight where you see the misfire code. I think cyl 8 is the last plug closest to the firewall on the passenger side.
Also, pull and inspect cyl 8 spark plug. Is it charred? Is the end terminal where the boot connects loose? Sometimes, if you inappropriately wiggle the boot it works the plug's terminal nut loose.
Also just to post this to your thread. Because my fix exhibited the same symptoms as your issue. Flashing SES light no power. Limp. For any future people trying to fix these symptoms. Check the passengers side O2 sensor electrical connector. Mine was corroded with green corrosion. Took the dumb dealer 30 days to never figure it out and tried to charge me $2500. Talked them down to $500 for poor service. Now I've fixed everthing myself since 2008. Rover On!
