narrowband or wideband O2 sensor
RE: narrowband or wideband O2 sensor
You are overthinking it.
http://www.roverparts.com/Parts/ERR1834.cfm
http://www.roverparts.com/TechTips/k...ons_system.cfm
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Zirconia O2 sensor (narrowband/wideband) Creates an output voltage corresponding to the quantity of oxygen in the exhaust relative to that in the atmosphere.
Titania O2 sensor Does not generate its own voltage, but changes its electrical resistance (ohm) in response to the oxygen concentration. Titania O2 Sensor Cable designation: red - 12 V (heater) white - 10.8 V return (heater) 1.2 volt stay always inside the sensor yellow ground black - sends resistance (ohm) signal to the ECU
red - 12 V (heater)
yellow ground
red - 12 V (heater)
yellow ground
