Need the collective wisdom of the forum elders.
Old 02-02-2019, 10:53 AM
mln01's Avatar
Your DII can go 75-85. Who knew?
One way to address the problem would be to not drive faster than 74 mph. 🙂
Old 02-02-2019, 12:10 PM
Ben Matheson's Avatar
If you aren't doing 80 on the interstate down here you'll get rear-ended
Old 02-02-2019, 12:16 PM
Received 1,464 Likes on 1,195 Posts
Have you swapped the tires front to rear to see if the vibration follows
Old 02-02-2019, 12:26 PM
I will do this next I was concerned the steering damper would mask things if moved up front but I guess it should make a noticable change even so
Will report back after rotation
Old 02-02-2019, 12:52 PM
zuke's Avatar
Has it ever been in a front corner collision? I had one that acted similar due to a slight kink in the frame.
Old 02-02-2019, 06:55 PM
Extinct's Avatar
Received 1,402 Likes on 1,002 Posts
I had a chevy truck throw a ring gear tooth once, immediately started whining like crazy. Bought a non-driving disco once where the middle shaft in the transfer case had the retaining ring come off and the shaft walked out until the gears were grinding I would check your differential fluids as well as the transfer case fluid, check the rear diff flex joint. If none of that checks out drop your diffs one at a time and check the gear conditions.
Old 02-18-2019, 11:59 AM
Update and resolution. Found a really good tire shop with a road force balancer to really check tires and rims. Found a bent rim that was hard to see unless spun at just the right speed. Swapped the rim with an extra I picked up and now she's smooth as glass.
The following 3 users liked this post by Ben Matheson:
Fallstaff (02-18-2019), Lisa Bunch (02-18-2019), NewToTheTwo (02-18-2019)
Old 02-18-2019, 06:11 PM
Extinct's Avatar
Thanks for the follow up, good to hear you found it and not too serious.
aemnky606
02-18-2019 04:12 PM
san988
10-29-2013 05:41 PM
Spencerfitch
09-22-2012 06:50 PM
javoli001
10-22-2008 06:23 PM
LiftedRover96
02-07-2006 10:41 PM
Quick Reply: Need the collective wisdom of the forum elders.
