Need help with installing dashboard switch
Hello
I want to know how to install a switch on the dash for accessories. To the left of the climate control unit, I notice there are placeholders where you can install factory-looking switches.
If this is possible, where can I buy the switches that go perfectly in those spots?
How do you pop out the placeholder switches?
How do you install the real switches? Where is the best place to tap for power?
Thanks in advance and apologize if there is already a thread on this. I did try looking first and didn't find what I was looking for
Al G
'03 D2 SE7
Al G
'03 D2 SE7
Also if anybody can direct me to the easiest source to tap a switched 12V power, it would be very much appreciated
Sincerely
al
The switches just pop out, take a small screwdriver and pry on the horizontal edge of the cover (or switch) I was going by memory on this so I went out and confirmed that this works, and it does. Interesting thing is that the blank places have wiring and a connector attached to the blank plate. I'm thinking this is because the same wiring harness is used for all Discos, wonder what they go to (I don't have SLS so maybe that is one of the answers)
