Need help with a leak
Old 08-18-2018, 04:41 PM
duscarter's Avatar
Default Need help with a leak
I bought a 2001 Discovery 2 for $650. It started and sounded good. The seller made me aware it had a coolant leak and the 3 Amigos.
I owned a BMW before and felt comfortable working on the truck. It is not a daily driver, so I have time to piddle with it.
Started by replacing the coolant tank and water pump. The leak looks like it is coming from behind the water pump. I rented a pressure tester from advanced, but the leak is so bad it wouldn't build pressure. When I pour water in it pours right out.
After a lot of reading on here, I decided to do the timing cover gasket. Just finished with that. Well almost, the oil pan still needs to go back on.
Put all the hoses back, and added some water. It poured out again.
Any ideas?
Old 08-18-2018, 10:31 PM
User's Avatar
ok.. so above the water pump there is a pipe that goes into the lower intake manifold.. there is a possibility that it is leaking. 3 10mm bolts go there.\
that's funny.. I also just bought a 2002 Disco for $650 and had to do the front cover job. It worked fortunately
Old 08-19-2018, 08:25 AM
duscarter's Avatar
Thanks, I have lifted the front of the intake and looked at the hoses. Probably should have put some water in it to verify they weren’t a problem.
Head gasket and cracked block keep running through my head after reading this forum. There was no coolant in the oil,
Old 08-19-2018, 08:34 AM
There is a bolt that holds the water pump that's also a place to drain coolant Check that out
Old 08-19-2018, 09:43 AM
duscarter's Avatar
Thanks redwhitekat. I've pulled the water pump 3 times already. Did the gasket first. Then bought a new pump and did it again. Then did it one more time when I did the timing cover gasket. I couldn't find all the bolts on the timing cover until I removed the water pump.
Old 08-19-2018, 12:43 PM
Received 1,131 Likes on 781 Posts
Although it is unlikely there are 2 nylon type hoses that go to the throttle body heater, they pass under the intake manifold if one is cracked or broken it could be the cause. You should be able to close them off on the right side of the engine bay to eliminate them as a cause. Number 7 & 8 in the diagram below.
Old 08-19-2018, 03:08 PM
duscarter's Avatar
I pulled the ac compresser off to have a better look at those hoses. It looks like the leak is below that behind the exhaust manifold.
There was nothing in the oil when I drained it.
Old 08-19-2018, 03:34 PM
Saturnine's Avatar
So the back side of the head on the drivers side?
Old 08-19-2018, 03:37 PM
duscarter's Avatar
Looks like the front drivers side.
Old 08-19-2018, 11:05 PM
Saturnine's Avatar
Between the head and the block? Take a pic!
Quick Reply: Need help with a leak
