need your thoughts
need your thoughts
I am getting stumped on this one. I am getting a vibration around 2500RPM. Does it in every gear, at any speed, and in neutral. The harder I push, the more she shakes. I can let off and it will go away (almost).
My next step is to remove the belt and run it down the street (cold engine obviously) just to make sure my PS pump or something isn't about to take a dump.
I have new plugs and wires, induction and t-body cleaning, ATF flush, 44K in the tank 2 times in the last year... I can't hear a cut out in the exhaust ( resonator removed ), so I am getting a little stumped here.... Engine is nice and quiet with no leaks...=)
any thoughts?
any thoughts?
RE: need your thoughts
I won't attempt a guess, but this looks like a cool website. http://www.vibratesoftware.com/html_...ed_Related.htm
Seems like a good idea taking the belt off.
Does it vibrate standing still with engine revved up to 2,500? If so, no need to drive it. Just remove belt and see. Sounds to me like a possibleignition issue (coil?). I once replaced a bunch of hardware like you did and it was a bad plug. I had to have that engine hooked to acomputer to get it figured out. That was the best $50 I spent on that vehicle. So, you might go back and double-check the wires, plugs and coil. Hope you find it right away.
Just doesn't hit as hard on idle. You can really feel it under load. Oh, and don't feel too bad for me, everything I have replaced so far has been needed, unfortunately. I haven't thrown any parts at it, other than a used MAF I got for $30 on E-bay. I figured it wouldn't hurt to have a spare.
maxman
01-28-2015 08:08 PM
Crosbo
09-18-2011 08:16 PM
