New DII owner serpentine belt walking
You have a pulley out of alignment somewhere.
The most common ones are the water pump and power steering pump.
When the bearings go bad in either one of those the shaft can slide out (or in).
I would remove the belt and start spinning pulleys and checking for play.
A bad belt tensioner could also be the culprit.
Pump replacement is the only option, I'm afraid. I was lucky, because the used engine I bought when I first got my Disco came complete with a pump, so I was able to use the pump from my old engine when this exact thing happened to mine.
Check Roverland, Car Cannibal, or local used places for another power steering pump, as even rebuilt units are quite expensive.
Marty Mar, I'm in Versailles and just purchased a '01 Discovery II, would you mind sending me the information on the parts guy. I think I have seen him on CL, but can't locate it anymore. Thanks. dbrangersems@yahoo.com
esaycho
10-12-2005 03:24 PM
