New rock sliders are installed!
Old 06-06-2009, 06:01 PM
Urban Panzer's Avatar
Originally Posted by gilder
"I started with an 1/4 inch hole and worked my way up to 7/16 jumping every 3 or so size bits. I had to drill from both the outside and from the underside and I used an old right angle Milwaukee drill that is about 30 years old but still works great."
Mike, I haven't seen any yet that use the factory holes, not even the unit from RTE. I'd be a lot more likely to install if they used the factory holes, so if you know of a manufacturer that uses them please let me know.
Mine are drilled for all the factory holes, you can use all of them if you like, but 3 bolts in front door area and 1 or 2 in the rear is enough. Then I just re-used the trim plugs that hold the sill on to fill in the un-used holes. They also bolt to the chassis out riggers as well.
Im in the UK, so I doubt you would order a set from over here due to shipping, but someone over there must do a similar design??
Old 06-06-2009, 06:06 PM
gilder's Avatar
Mike, I was referring to drilling into the vehicle, not the sliders. Panzer, can you send pics of yours?
Old 08-02-2009, 08:33 AM
nateb006's Avatar
Our Sliders do require drilling of the sill. If the truck is ever sold without the sliders, the stock sill cover will hide the holes.
Take Care,
-Nate
Old 08-02-2009, 09:33 AM
Chrisinhouston's Avatar
I am very happy with the sliders Nate provided for me. The were easy to install using only a hydraulic floor jack. I have an Milwaukee right angle 1/2 drill (almost an antique as it is all aluminum and must be 30 years old) that made drilling the new holes a cinch. I chose to drill the rear hole first and then moved to the front, that way the sill was in place for all the other holes. Unless you have a step up drill bit you need to start with a 1/4 or so and work your way up. I used some machine oil to keep the bit from dulling and overheating. When I was done I dropped the sill and cleaned the holes with some Brake cleaner solvent and then sprayed some black Rustoleum paint. Then I reinstalled the sills protectors. That being said, there is probably a low corrosion factor because the car's sill material is thick enough and with the sill guard in place and the bolts tightly fixed in place there is little room for water to accumulate. Unless you drive in salt water or heavily salted roads in winter I can't see why the car would rust in these holes anymore then elsewhere underneath. Nate puts a slightly textured coating on before the black paint so they are pretty much slip proof too.
I would also add that the sills act as a running board and even my short wife has not complained that it is any harder to get in then when we had the factory running boards.
Old 08-03-2009, 12:12 PM
JBEGIN's Avatar
Cool, I want a set, i still have the plastic sill cover.
Old 08-03-2009, 12:14 PM
05LR3AZ's Avatar
Default rock sliders
Those are pretty sweet looking and the design I've been looking for. I might just have to inquire about these! Thanks for sharing.
Old 08-03-2009, 12:51 PM
Disco_Fever's Avatar
I've a set on my truck as well, and can't say enough about the product or the level of service I received from Nate.
Old 08-03-2009, 03:31 PM
oysterhead's Avatar
do these sliders stick out beyond the door panels?
i'm asking because I was on slick trails this weekend that posed potential for body damage because of small trees along the trail.
would these sliders protect the doors from trees? or just ground level obstacles?
if sliders wont protect from trees, are there any other solutions?
Old 08-03-2009, 04:32 PM
They stick out past the doors if you order them with the nerfs. They'll help things glide along the sides of your truck and will at the very least reduce damage.
Old 08-04-2009, 06:12 AM
nateb006's Avatar
When ordered with the nerfs you'll have plenty to keep you off the trees. Here's a picture from the RR, 09. This is John (Roverdude)'s truck.
Take Care,
-Nate
drowssap
07-28-2014 01:21 PM
WNYErikDiscoII
12-20-2013 03:55 PM
Blakesrover
02-20-2013 10:31 PM
Cosmic88
01-21-2011 08:47 PM
discojosh2000
11-06-2010 11:34 AM
Quick Reply: New rock sliders are installed!
