No CEL random misfire at idle
2001 d2 with 118k miles on it, well maintained. About a month ago I developed a random misfire at idle while at a stop light or when parked. No check engine light. I was due for plugs and wires so those were changed, as well as coil packs and top end gaskets to cure the leaky valve covers. I haven't noticed any difference in fuel economy. Under load the disco runs fine as it's intended to do. I don't have any mixing of fluids and I have not lost any coolant or oil. Completely leak free. I have not done a compression test yet. Around 200 miles ago I heard a rattle on the on ramp under good acceleration and was thinking it may be the cat? Tapping on either cat doesn't reveal any noises and I only head it one time. Engine doesn't tick or over heat whatsoever so I'm aggregated by this obviously. Any ideas please chime in.
Originally Posted by jslatz
(Post 621221)
no one has an idea? |
No CEL really throws things off. Without a troublecode anything is just guessing, which can be expensive.
IACV, MAF, CmPS could all have issues, but would normally throw a code if there is a problem with them. You could also try looking for any vacuum leaks? |
Originally Posted by robert.juric
(Post 621365)
I know you replaced the coil packs but I would start there. Check all connections. I had issue similar to yours and did not get CEL. Replaced the packs and it was gone.
Originally Posted by matt3502
(Post 621587)
Make sure your idle air control cage is plugged in. If it is, clean it out really well. I used brake cleaner, but throttle body cleaner is probably more recommended.
You say you're not getting any CEL on dash, but did you check for codes? If you bought it used, the dash light may be disabled or covered.
Brian. |
| All times are GMT -5. The time now is 04:59 AM. |
