No compression on #1 on Disco 2?
A buddy of mine has a 2000 Disco 2, and it has a miss. He pulled all 8 plugs for a compression test and cylinder #1 was at ZERO. All others were between 145-150. No coolant issues / smoke, etc....any thoughts? Thanks -
Maybe a blown head gasket or a stuck or burnt valve.
Willie |
sounds like you need a rebuild......
pull the heads and take them in....have the shop look for a bent valve....if they are good...have them cleaned up and a valve job done and have the heads decked!!! change the gaskets and get her running again |
| All times are GMT -5. The time now is 08:32 AM. |
