No Compression
#31
#32
#34
Sure would have been nice if the shop could have supplied you with pictures. I've been a mechanic for 39 years and never seen a broken timing chain. Seen hundreds of worn, sloppy or barely let the engine run...but never a broken chain (belts, several).
Anyhow...this just keeps bugging me...the not knowing what caused the issue. Engines don't normally need a water pump, running when they go into the repair...and come out with a broken chain.
Hopefully...I can sleep tonight not knowing...lol.
Brian.
Brian.
LR03NJ (11-11-2016)
#35
Brian.
Brian.
#36
Sorry to hear of your D2 woes and the horrendous costs to you. IMO the mechanics could have established a broken timing chain far sooner if they had known what they were doing and cranked the engine and looked into the timing cover via the oil filler hole or even taken one rocker cover off. It is evident something was seriously wrong as if all the piston rings were broken (highly unlikely) there would still register some cylinder pressure albeit very small. It does sound like you have been real unlucky with this problem and unfortunately picked up the bill for it. Hope all goes well from hereon.
#37
...my bad, I guess I focused just on the "immobilized" issue after doing a repair, for which this "hack" helped me. I now see that his main prob was different, Oops! ;-]#
LR03NJ (11-13-2016)
MacRR
05-05-2008 08:29 PM
