No Start after motor swap 4.6
Old Apr 17, 2013 | 11:27 PM
pgoodrich's Avatar
Default No Start after motor swap 4.6
I just got back into the rovers again 99 and 03 D2. I recently pulled a 4.6 out of my 2003 and put a rebuilt 4.6 back in. After completing the engine swap I can't get it to start up. It cranks over but I have no spark. I tested both banks and still get no spark. I checked all the connections on the coil pack. I reused the CKP from the old motor. Could that be the problem? I read in the RAVE that I need to reset the adaptions using a testbook if the CKP or flywheel have been removed, which of course mine were. Please Help. This is my sons rover and needs it for school.
Old Apr 18, 2013 | 12:39 AM
Don't think reset is a must. The CKP is frequently replaced incorrectly, and the spacing is so critical no spark signal is created. The spacers and nuts must go on in exact order, like block+sensor+spacers+nuts. Here's some data on the CKP attached. I believe if it is working right you should be able to see some low rpm on your OBDII scanner when cranking. If the tip was bent or covered with metal fuzz that would also be a problem.
File Type: pdf
Old Apr 18, 2013 | 01:14 AM
pgoodrich's Avatar
Thank you. I will double check the ckp in the morning and post back.
Old Apr 18, 2013 | 08:43 AM
Two other easier quick checks would be resetting the alarm and the inerita switch, both of which can also cause a no start.
Old Apr 18, 2013 | 10:41 AM
Yep, that inertia switch takes down the main relay (sensors, all fuel injectors) and the fuel pump relay. If OK should hear pump run for like 2 seconds at attempt to start.
Old Apr 18, 2013 | 07:24 PM
pgoodrich's Avatar
Thank you. You were correct. I must have installed the CKP incorrect I had the spacer in the wrong location. I reinstalled the way Savannah stated and now she fired right up. See the link.
Old Apr 18, 2013 | 07:37 PM
Get rid of that orange dexmud coolant, flush and go green 50/50 (PEAK, etc.). 180F stat might be a good idea.
Old Apr 18, 2013 | 10:58 PM
pgoodrich's Avatar
(Savannah) Great info on your link below. Any other suggestions?
Old Apr 19, 2013 | 12:13 AM
pgoodrich's Avatar
Off topic what brake pad do you recommend? I need to replace the fronts. The rear are genuine Land Rover. I was thinking to get genuine LR for the front to match. Would like to hear from the experts!
Old Apr 19, 2013 | 12:37 AM
Front drive shaft rebuilt or replaced? Many members "rave' about their Akebono pads.
bennyb43
Dec 11, 2013 08:17 AM
me 2
Jun 24, 2012 12:49 PM
me 2
Jun 17, 2012 07:24 PM
DuplinDisco
Apr 26, 2008 03:14 PM
kraelo
Mar 16, 2008 05:09 PM
