noise
sounds like i have a bird in the dash behind the right airflow vent.
not all the time but when the air flow is high. thoughts? |
RE: noise
Junk in the blower motor, behind and below the glove box.
RE: noise
Let's hope that's all it is. The blower had to be replaced on my 02. keep an eye on it.
RE: noise
No, don't keep an eye on it, remove it and clean it out before it fails.
RE: noise
is cleaning a due it yourself?
difficult? |
RE: noise
Sure, it is easy to get in there and remove it. Once you get it out you can check for junk in the or spin the blow cage and see if a bearing is failing.
| All times are GMT -5. The time now is 08:47 AM. |
