Noise in engine .. Help!
That noise is either a slipped liner or it is a bad main bearing.
If it is a bad main bearing or rod bearing, don't drive it as it will throw a rod and put a hole in the oil pan or the block.
If it is a liner - the way you tell is -
If it is quiet in the first three minutes when you start it and then after driving a mile
this sound comes - then it is a liner slipped and thrashing up and down.
Solutions:
1) If a liner - PIN the liner with a screw into the block.
2) If it is a bad rod or main bearing - replace all the bearing shells and that will solve it.
You may have a scored crank shaft now - and if that is the case - whole rebuild.
A 2003 engine does have slipped liner problems - so cut your losses.
Fold the cards.
Solutions:
Fold the cards.
tobob1
11-27-2006 02:11 AM
