Non-ACE combined PS reservoir?
You mean perforate the dual chamber reservoir 'W/ACE'? Just use a hot bent metal rod and melt a few holes through bottom of partition, or get a cheap used Non ACE reservoir(if you have ACE torsion bars removed).....
You are only doubling the volume if you have ACE disabled, otherwise you are just sharing the volume, and if one side hose fails, then you lose both volumes
