normal idle rpm
normal idle rpm
I was getting a bit of a chug chug kind of noise at warm idle. I had two mechanics listen to it and both said they heard nothing out of the ordinary. One said it was probably from too low of an idle. When warm my '03 idles around 400rpm. If I rev it to around the 700-750 rpm range I hear no noises. Is my idle too low and is it adjustable? My idle is a bit choppy, could I have a vacuum leak causing low idle and choppyness?
Here's the thread on throttle body cleaning...
https://landroverforums.com/forum/sh...ad.php?t=19664
The IAC valve is very simple to clean too...just unhook it from both tubes, disconnect the electrical connection, pull it off (you need to of course also unbolt it from the 2 plastic clamps) and spray the crap out of it...don't be shy with spraying it down until it's sparkling clean...a lot of junk is going to come out of it if it's the 1st time it's been cleaned.
On the original question my D2 idles consistently a hair below 750...
