-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Now the vibration (https://landroverforums.com/forum/discovery-ii-18/now-vibration-51718/)
PAPAGALLO Aug 3, 2012 04:03 PM
Now the vibration
Hello guys
hope all is well!my 2004 disco has been great to me up to the 56000 miles it has.there was a little vibration so i decided to check u joints and they were bad.now after changing the front drive i notice a heavier vibration at around 30-50 mph.what do you think this can be? Mecahnic says rear u joints were fine just did the front.any input is greatly apreciated.thank you.
DiscoRover007 Aug 3, 2012 04:06 PM
When was the last time you got an alignment? Tires balanced and rotated?
It's possible that the drive shaft wasn't put back the way it was originally oriented. I've heard of guys having vibration because of that so when I had mine rebuilt I marked mine with a silver sharpie on both sides of where the shaft attaches to. This might not be true but I did it to make sure to avoid problems.
EDIT: Also check for balance
PAPAGALLO Aug 3, 2012 04:19 PM
If this is so how can it be oriented in the correct way?thank you for your quick response.
A5scott Aug 3, 2012 07:37 PM
also, a slim possibility that your new driveshaft is not properly balanced. this is what I'm dealing with, but it's an easy fix. where did you buy your replacement?
whiski runner Aug 4, 2012 05:53 PM
I too am having the same trouble so I've decided to take both front & rear shafts out and have them balanced. My vibration doesn't start till I hit 55-60 on up.
lr2001silver Aug 4, 2012 10:58 PM
Also agree that the drive shaft may not be balanced correctly. That will cause a viberation and a worn tire or a bent rim could be to blame.
Disco Mike Aug 5, 2012 07:55 AM
Did you have the drive shaft rebuilt or replaced with a new one? If rebuilt, did your mechanic replace the centering ball, if not, that will be your problem.
Did your mechanic grease all the u joints when installing them?
For a simple test, remove the front drive shaft, shift into high lock and drive on the rear shaft only, is the vibration gone, if so bad rebuild.
dwatterson1 Jan 23, 2017 06:23 AM
my 2003 disco II experienced the vibration problem , it felt like I was driving on a very rough road . I stopped the truck and checked the tires , all were ok .I started back up and the vibration had stopped . Any ideas ? It then showed a code that I haven't checked yet , I will do so today .
