O2 sensor connector broken...
Bought an 04 Discovery 2 that had a CEL for an O2 sensor not reading. Found out the drivers side O2s connector is damaged on the engine harness side, and needs replaced. So I am wondering if any of the folks here have run into that before, were you able to find a connector to replace it with? I'd also welcome whatever other help anyone felt like offering? I'm in the Denver area, Aurora specifically, kinda in a jamb here, as I sold my only other car to buy this, and I was planning for this to be my daily driver, now I'm stranded, maybe that was a bad idea...
You can buy a harness extension and cut it to fit what you need. I believe Honda shared the same connector for a certain age range but I don't remember off hand what that was. However soldering it together could prove difficult. Look up Roadside Werx in Englewood and they might be able to help you out. Probably a good idea to get to know those guys anyways....I pretty much buy all my parts from them these days and don't bother with online orders if I can help it.
Also, the car will run just fine with O2 sensor issues. Now passing emissions is a different story but if the only codes thrown relate to the O2 sensors you're gonna be fine to drive it.
Mntnceguy (09-13-2021)
...on Amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1, went ahead and ordered one, hoping it'd be right.
if my memory serve me right, the downstream o2 connector on the o2 sensor plugs into the the upstream o2 connector, i think i ran into this before, i had a few bad wires on my o2 engine harness before the catalytic convertor and i had a old o2 rear sensor lying around and i think they plugged right in
Mntnceguy (09-14-2021)
