Which O2 Sensor does code P0154 refer to?
I changed my O2 sensors and I keep getting the same code after clearing it a couple times. I get the code P0154 which I think is bank 2 sensor 1. Can someone confirm? Is this the front drivers side?
I'm going to get a replacement from Atlantic British and just want to make sure I get the correct one. |
No, it is the passengers front 02.
With your mileage you should be replacing them all. |
Keep in mind that 90% of all Rover O2 codes are due to the need of a tune up.
I did change all 4 O2 sensors, this is the one code I am getting now after changing them, there were no codes before I changed them, I did it as maintenance. I changed the ignition wires to magnecores and the plugs are new.
Should I try a new sensor from Atlantic British? |
Originally Posted by Spike555
(Post 121172)
(Post 121172)
Thanks for the heads up, Brendan |
With that code, no sensor detected, check your connections and then if all is good then you may have gotten a bad O2.
Call the place you got them from and do a exchange. |
(Post 121193)
I think that bank 2 is passenger side and sensor one is the front one.
154, the ECU sees it but there is no activity from it, as in dead. I would suggest you check and clean the connection, if it is still there then contact whoever you bought them from and get it warrantied.
