obd port?
I feel like an idiot, I have a OBD II scanner, and can't figure out where it plugs into. I assume its under the steering collumn in the fold down compartment with the fuses. Can anyone clarify this, or shed some light on the subject? I bet I've looked under the dash for an hour.
Thanks I should add its a '02 Discovery II. I looked to make sure its OBD II compliant and according to the dataplate it is. |
RE: obd port?
Look under the driver side just in front of the gas pedal,where the fuse panel
meets the lower cover. |
RE: obd port?
Thanks I found the plug. The dealership pushed it under the dash so it wasn't exposed.
| All times are GMT -5. The time now is 08:13 AM. |
