-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   OBD Software and OBD to USB cable for Land Rovers. (https://landroverforums.com/forum/discovery-ii-18/obd-software-obd-usb-cable-land-rovers-30826/)
johnkbl May 3, 2010 02:55 PM
Has anyone here has bought a OBD to USB cable and downloaded any free OBD software?
Experiences? Good? Bad?
Where can I buy one cheap cable/software that really works with Rovers?
I need to check the codes of my car, but... since the car is parked 95% of the time and is something like a toy for me, I do not want to spend money in an expensive code reader.... I need a cheap tool to read the codes and a couple of things more...
Experiences welcome!
(I have a `94 Disco 1!! 3.9)
Disco Mike May 3, 2010 03:53 PM
I doubt you'll find any on the market under a few thousand $$$$$$$$$$$$$$$$$$$$$$'s.
Go to Canobd2 and click on products, then tools, look closely at the 3130 and if interested, I know where you can buy them for about $134.
johnkbl May 3, 2010 04:35 PM
Thanks Mike for the help....
Checked the tool, but it is still does not fit into my budget (Well.. I even have no budget!!).
Here are several links to different softwares that are free, but, since the Disco I is not OBDII compliant, I do not know if that software will be usefull for me..
http://ecomodder.com/forum/showthrea...calc-7490.html
I am looking for something like this:
http://www.drewtech.com/products/Mon...ngooseiso.html
But it must work in my Discovery 1
Here is the explanation to DIY a cable:
http://www.aldlcable.com/
Question:
Disco 1 is OBDII compliant?
tweakrover May 3, 2010 05:10 PM
look under the passenger seat from the back, there is a screen that shows the code. http://www.fourfold.org/LR_FAQ/RR/FA...ult.Codes.html this will tell you what they are. the 94s and 95s have OBD1 systems which are much simpler, good luck.
brianb883 May 3, 2010 05:20 PM
Mike,
I'm not sure he meant an actual diagnostic utility, but just an OBDII to USB cable. Those are around the internet for around $15....
http://www.virtualvillage.com/usb-ob..._medium=shcomp
Here is some good software starting at $70...
http://www.scantool.net/software/
Although I'm positive there are freeware OBDII programs floating around.
NiteTrain May 3, 2010 05:53 PM
the cable/software for OBDII are around $15 on ebay but I don't know about OBDI.
Disco Mike May 3, 2010 06:19 PM
You can buy an adapter to hook onto that scanner and then you will be able to read the OBD1.
