OEM or Aftermarket....MAF Sensor?
Hey guys,
I need to get a new MAF sensor and air intake hose (going used here). Opinions and experience would be appreicated - OEM Bosch MAF sensor (around $127 w/ ship is the best i've found) or aftermarket, for example- Autotrust plat MAF sensor w/ 5 year unlimited warranty @ $54 w/ ship Link: http://www.autopartswarehouse.com/sk...%26+Drivetrain Anyone using an aftermarket MAF sensor? Results? Suggestions? Thanks in advance. |
have you tried cleaning your old MAF sensor?
Originally Posted by NiteTrain
(Post 194205)
OR, if anyone knows of any other tricks or things to do to bring my current MAF sensor back to life...please share.
Otherwise, i'm still open to hearing others opinions on replacing with an aftermarket part. |
if you've cleaned it really well with electrical contact cleaner and it still doesn't work I think that's about all you can do...sucks but sounds like its time for a new one
I've been using an aftermarket MAF for over a year with no problems. I don't remember it being that cheap, but it was under a benjamin.
that's not bad...rover parts are all about the benjamins
Grab an OEM MAF from Will Tillery (roverguy.com) for $125 and be done with it. I've been burned by 2 separate "new" aftermarket MAF's on 2 different vehicles (Disco II and SLK320) - I'll never make that mistake again. A good MAF makes such a difference in how the vehicle performs....don't roll the dice over ~$60.
Originally Posted by blast20
(Post 194330)
Thanks. |
It will not run right if there is a leak after the MAF.
You talking about this hose? Land Rover Fuel System Parts | Hose Air Meter To Manifold |
