OIL FILTER 2003 SE
Old 10-29-2007, 03:39 PM
bean0714's Avatar
Default OIL FILTER 2003 SE
I have a 2003 SE I just Purchased it USED& I want to get an OIL CHANGE. Which OIL Filter should I use. I have heard that Factory Land Rover or K & N is good , but fo not use the ones from the OIL CHANGE Places. Can anyone HELP me ?
Old 10-29-2007, 05:03 PM
llesra's Avatar
Default RE: OIL FILTER 2003 SE
anything other than fram, penzoil, or quaker state oil filters will work fine.
okdiscoguy's Avatar
K&N and Mobile 1 filters are good. 03's with an early production date need to have the oil pump watched. If your oil light ever comes on, stop the truck and check the oil. I would only use one of the 2 above filters.
Old 10-29-2007, 05:09 PM
Dahne23's Avatar
i bought the mobil 1 and gave it to the oil change guys. like 10bucks from autozone
Old 10-29-2007, 09:08 PM
geotrash's Avatar
K&N 3001
Old 10-29-2007, 09:37 PM
ajh's Avatar
ajh
ajh is offline
Using a filter magnet as well won't hurt.
Old 10-29-2007, 09:58 PM
DeepBlueWater's Avatar
I too use the K&N with Mobile 1 synthetic oil in my 2003 Disco. Doing very well...
Be sure to read the owners manual for the proper oil and filter change procedure on your 2003. It reads that the oil should be drained and then replinished before removing and changing the oil filter. Also, it describes prefilling the filter with oil to avoid a dry oil pump situation.
MWmG
Old 10-29-2007, 10:52 PM
Fonzie's Avatar
ORIGINAL: ajh
I just picked up a K& N 3001 for my next change. I was wondering about those filter magnets...are they really going to make any difference? I mean a good quality filter is designed to stop all but the tiniest micron of a particle from passing through. And is there any chance that the magnetic field might affect the spring loaded by-pass valve?
Old 10-30-2007, 12:46 AM
geotrash's Avatar
You're correct. The magnet is not necessary as the filter media will catch the beasties as they pass through the filter anyway. They can come in handy however if you regularly cut your filters open to look for debris because it will collect ferrous debris in one spot for easy sifting.Any pieces big enough to have a part number onthem are usually a bad sign [8D]
Cutting filters openis standard practice in heavy equipment and aircraft operations, and I've done it many times. Never used a magnet though and caught lots of debris over the years anyway. I drag a magnet over the filter media once I've stretched it out and catch debris that way. Works fine.
Dave
Old 10-30-2007, 03:17 PM
ajh's Avatar
ajh
ajh is offline
Will a K&N bypass if it won't allow oil-flow?
Quick Reply: OIL FILTER 2003 SE
